I am using SourceTree Enterprise 3.4.13.0 on Windows 10.
After a Windows Update Today it does not start anymore.
Only see splash screen then it closes.
Tried uninstalling Reinstalling, nothing helped.
In the SourceTree.log I see this error:
ERROR [2023-06-14 09:23:59,047] [1] [Sourcetree.Composition.VSMef.Net48.VSMefCompositionManager] [Log] - Unable to load MEF components
System.InvalidOperationException: Die Sequenz enthält keine Elemente.
bei System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
bei Microsoft.VisualStudio.Composition.PartDiscovery.GetElementTypeFromMany(Type type)
bei Microsoft.VisualStudio.Composition.RuntimeComposition.RuntimeImport.get_ImportingSiteTypeWithoutCollection()
bei Microsoft.VisualStudio.Composition.RuntimeComposition.RuntimeImport.get_IsLazy()
bei Microsoft.VisualStudio.Composition.RuntimeComposition.RuntimeImport.get_LazyFactory()
bei Microsoft.VisualStudio.Composition.RuntimeExportProviderFactory.RuntimeExportProvider.GetValueForImportSite(RuntimePartLifecycleTracker importingPartTracker, RuntimeImport import)
bei Microsoft.VisualStudio.Composition.RuntimeExportProviderFactory.RuntimeExportProvider.RuntimePartLifecycleTracker.SatisfyImports()
Can anyone help?
Deleting
%LOCALAPPDATA%\Atlassian\SourceTree.exe_<UID>\3.4.13.0\Assemblies.cache
%LOCALAPPDATA%\Atlassian\SourceTree.exe_<UID>\3.4.13.0\Composition.cache
helped!
Thank you so much glad someone was able to solve this.
Same issue for me and this worked. Thanks!
Very helpful for me too
FYI - On my machine, the files were located under the Atlassian folder:
%LOCALAPPDATA%\Atlassian\SourceTree.exe_<UID>\<Version>\
Worke for me as well, thanks!
고맙습니다. 덕분에 해결 했습니다!
Seems that this issue reappears and the above fix has to be applied repeatetly
So i downgraded to 3.4.12 and the issue is gone
Seems to be some deeper issue with the 3.4.13 version
Thanks for posting. This worked for me.
Worked for me
Worked for me after this weeks regular windows update that I declined but somehow it was applied regardless. For what its worth these are the folders in which I needed to delete those files:
C:\Users\**me**\AppData\Local\Atlassian\SourceTree.exe_Url_re5thcoffnnkdlp540ilqzrn33oj41rm\3.4.3.0
C:\Users\**me**\AppData\Local\Atlassian\SourceTree.exe_Url_n3rdypildipi022uybkie3xafvtaqehx\3.4.8.0
Worked here too! Awesome!
Same problem. Solution works like a charm
worked for me too thanks!
Worked for me - thanks a bunch.
Worked perfectly thanks!
Worked for me!
It works for me too. Thanks a lot!!!!
It works for me too, thanks!
Worked for me.. thanks!!!
This worked for me. Thanks!
Thks so much. it works
Thanks so much. It worked like a charm!!
This worked!
"Unable to load MEF components" is not a bug, it's a feature! This happens so frequently it's disturbing why developers do not fix this or auto-remediate for this issue. Incredibly frustrating when this happens.
EDIT: Got tired of this issue happening so often, even on latest version at time of writing, so I stopped using Atlassian SourceTree altogether and started using something else.
Thank you so much!!
Thank you so very much! A big relief. Thank you.
This worked beautifully (on v 3.4.11). Thank you so much!
Worked for me in 3.4.13, now I'll upgrade :-)
Brilliant! Thank you.
We have fixed this issue in Sourcetree 3.4.14 and is available for upgrade.
Exact same issue here, deleting the single file solved it:
Composition.cache
However, the problem has recurred twice - will we see a fix soon?
came here same reason,
thanks for the work arounds.
Uninstall/reinstall seems to work at least from SourceTree-3.4.8 to 3.4.13
Thank for you help♥
Works for me as well. Thnx!
My entire team got bit by this bug after recent windows updates.
same thing happened here. glad to find this post quickly.
