Sourcetree - Fatal: ArgumentException encountered. WHY?
Claire Jamieson October 9, 2016
When doing a PULL request i always get this:
git -c diff.mnemonicprefix=false -c core.quotepath=false fetch origin
WHY?
Gratned, the Pull request is successful in the end but the fatal exception in the log always bothers me. Any ideas what is causing it?
22 votes
fanchi
November 11, 2016
I encountered the same problem. You can go to "Tools"-"Options", in the "Git" tab, at the bottom of this tab, see which Git version you are using. If you "use System Git", the error could be due to an old version of Git. You can either choose to update your Git of your system, or choose "Use Embedded Git", see if the issue can be solved. I solved my issue in both ways.
Claire Jamieson November 14, 2016
this seems to have sorted my issue too. Thank you!
denis-evseev
August 30, 2018
Helped me!
Eric Tarasoff
September 25, 2018
Thanks...this helped me too.
saeedeldah
November 3, 2018
Helped me
Deleted user November 12, 2018
I found the same issue, but I fixed after changing the Git options to "System Git"
gobater
November 29, 2018
Switching to Embedded Git seems to help. However, I would like to be able to use the one on my system which is newer.
I also tried to update the Credentials Manager for Windows as suggested here, but didn't work
Like Renshi LI likes this
barlieuy
December 2, 2018
Solved my issue! Thanks!
kimifc
January 30, 2019
yay!
Anthony del Busto
February 18, 2020
Choosing 'Use Embedded GIT" resolved my issue.
Sivasankar
March 13, 2020
Solved my issue too ! Thanks :)
Kartar Gill
October 25, 2016
I am also encountering the same problem.
Did you manage to find an answer to this?
alexfung
June 1, 2017
I am still getting this error. Switched between both gits, and downloaded the latest embedded git. No difference.
Jasper Lieber
March 12, 2018
I've been getting the issue below.  I just updated my embedded git, but still seeing issue.  Any other suggestions?
git -c diff.mnemonicprefix=false -c core.quotepath=false push -v --tags origin feature/2485__approved_claims_printing:feature/2485__approved_claims_printing
fatal: HttpRequestException encountered.
An error occurred while sending the request.
Like Lee JinBae likes this
