We have been using Git-flow for a while. On some projects it seems to work fine, But on most projects I can't use Git-flow.
Every time I press the Git-flow Button I get the following Error Message:
Git-flow not supported.
You'll need to upgrade to Git 2.6.4 or later.
We recommend upgrading to Git 2.24.1.2
When I use Git-flow via command line everything works as expected.
I am using Embedded Git with Version 2.24.1
My Sourcetree Version is 3.3.8.3848
I tried everything that I've found in here so far, but nothing worked.
Using source tree 3.4.8 and 3.4.9 (Windows 11 ) i'm getting this error, tried uncheck/embedded/check all possible fixes but nothing , i have git version 2.35.1 and embedded git 2.36.0 and i can't use Git-Flow!
After selecting checkbox "Tools/Options/Git/Git Version/Disable LibGit2 integration" the error message does not appear any more for "Git-flow/Start New Hotfix" action in my case.
(Win/System Git version 2.16.1/Sourcetree 3.3.9.3870)
