Sign up Log in
Sourcetree enterprise
Robert Bzdafka August 26, 2020
I just noticed you have Sourcetree for enterprise.  However, its not clear on if there is any functional differences between standard download and enterprise?   We use Microsoft System Center to package and deploy software to the laptops.    Is the only difference that sourcetree enterprise is bundled as msi file vs exe?
Mikael Sandberg
August 26, 2020
The Sourcetree Enterprise version allows you to specify the install directory and manage the installation at scale, the regular version does not allow that. All other functions are the same. You can find more information about Sourcetree Enterprise here.
Thanks.   They should have a side by side chart with the differences.   That might be helpful for people.   I also assumed it was free like the desktop version, but didn't want to assume.   Thanks for the info.
SERVER
