Sourcetree ignores github token and throws 403 error
Владимир
I have generated personal token on github and entered it in password field successfully, but when I try to fetch from my repo sourcetree throws me following error:
git -c diff.mnemonicprefix=false -c core.quotepath=false --no-optional-locks fetch --no-tags Room
remote: Support for password authentication was removed on August 13, 2021. Please use a personal access token instead.
remote: Please see https://github.blog/2020-12-15-token-authentication-requirements-for-git-operations/ for more information.
fatal: unable to access 'https://github.com/daisoto/room.git/': The requested URL returned error: 403
I have tried deleting my accounts from sourcetree and logging in again, but I still receive this error.
However, if I use console there is no error. Is proves that there is some error or my mistake in using sourcetree account managament.
22 votes
RU-GHETES Mihaela
August 17, 2021
I had the same issue and solved it in this way:
Open sourcetree, in the right click icon Settings (Repository settings) ->Remotes -> Select Origin and Edit:
Set URL/Path in the following format:  https://<token>@<git_url>.git
Turca Ciprian
August 17, 2021
works for me too. Thank you!
Like # people like this
Владимир
Thanks a lot for your solution!
Yet I have certain fear about this one, if someone gain access to your sourcetree client, they will easily find your token.
Like RU-GHETES Mihaela likes this
RU-GHETES Mihaela
August 18, 2021
Hi @Владимир ,
Even if it's not a nice one, that was the solution that got me out of trouble.
If you'll find another solution, please share it with us.
Thanks ,
Deleted user August 19, 2021
<3
Amy Nguyen
August 20, 2021
It woks on Mac. Thank you.
Abdullah Çınar
August 21, 2021
This is actually a workaround of a bug. The bug is, even if you remove/change the old authentication method, the SourceTree will still try to use the old one. It is restored even if you uninstall and make a fresh install of the app.
To prevent this after removing the old git credentials, delete Atlassian folder from all the appdata folders. Then go to Tools->Settings->Authentication and add a new Basic Github authentication. Enter the Github username(not the e-mail) and use your token as the password. It should work after that.
dwlorimer
August 23, 2021
This workaround works!  Thank you SO much!!   Sourcetree needs to get this issue fixed ASAP.
Beena Cherian
August 29, 2021
Changing the url only works for me
jack.lin
September 1, 2021
@Abdullah Çınar I delete passwd in AppData\Local\Atlassian\SourceTree and use token to login again. It works.
Like todagami likes this
todagami
November 3, 2021
@jack_lin this works for me!
Firemanchief52
December 3, 2021
I had the same issue, and found this link:
version control - When I try to pull or push in GitHub, I am getting an error message: "Please use a personal access token instead." - Stack Overflow
it require to modify (simply) the repository link.
it worked immediately.
authpala@workwave.com
December 14, 2021
Works me for Mac, Thanks!
Admin-Yukiko
February 24, 2022
Abdullah Çınar's solution has worked for me twice now. Once last year but I recently had to re-install Windows due to a system issue. I had forgotten how I had solved this issue before but thanks to a friend linking me to this thread, Abdullah Çınar helped me again.
Sergio Andrés Gómez Sandoval
March 17, 2023
I spent many days trying to find a workaround to this problem, I just deleted the Atlassian folder from C: - Users - MyUser - AppData and regenerated the authentication method in Sourcetree using Github and OAuth.
Worked like a charm.
Thank you Abdullah
Maxime Ege
October 17, 2024
Abdullah Çınar you found the solution, i just created an account to thank you so much
Karmandroid Singularity
Delete your passwd file in \AppData\Local\Atlassian\SourceTree\
howieyoung August 17, 2021
There are many different issues you might face.
We have tried to dig into each of them and resolve them all finally.
This article could be helpful for you: https://howieyoung.medium.com/suffering-from-the-latest-403-error-from-github-on-sourcetree-e04a844efd35
alfit
June 27, 2023
Krit Busayarak
August 17, 2021
I use SSH-based authentication. It works.
