Sign up Log in
Sourcetree keeps asking for login and password...
wborczykincuvo
April 15, 2012
2 accepted
Community moderators have prevented the ability to post new answers.
Post a new question
27 votes
stevestreeting
April 15, 2012
The Apple Keychain actually requires a username to be known in advance for the password lookup to work; if you don't include a username in your URL then SourceTree remembers the last username that was used to successfully log in to a given host and tries that one by default to look up the keychain entry. This can, however, be unreliable if you don't use the same username all the time on a given host. To make it unambiguous, include the username in the URL, like this:
http://username@host/path/to/repo
Alexey Strelkov
November 23, 2015
How was this even accepted?!! That didn't help and won't help.
Like 30 people like this
José Antonio Pérez López
June 26, 2017
Thanks. It worked. This is the correct anwser. No need to run pull on the terminal. In my case is simple as editing the repo URL and include my user as you mention, BEFORE the host. After that I restarted SourceTree and problem solved. The same applies for each new repo. Thanks! :)
Like Josh Winkelstein likes this
Culbert Zhang
January 29, 2018
I use code.aliyun.com for git trusteeship, then the sourcetree says "Password Required For user git on host code.aliyun.com". After I changed the url to "https://username@code.aliyun.com", the problem solved.
shrinathkopare
February 19, 2018
You can change the URL from 'Repository -> Repository Settings... -> Remote -> Edit'.
Like 5 people like this
Priyanka Bardhan
February 26, 2018
For me, after including username and putting the URL "https://username@code.aliyun.com" , it is still asking me for the password.
Like 7 people like this
Alyssa3467
March 9, 2018
Not only did this not help, but it broke things even further, making it impossible to do anything with the remote.
Like Sarah Mohammed likes this
Amit Kumar Dubey
May 2, 2018
That worked for me, Thanks!!
siyabongantombela
July 22, 2018
This didn't work for me. I'm using v 2.7 on Mac
nebrekab
September 27, 2018 edited
@Trung Vu 's Use system GIT within SourceTree's preferences solved the issue.
 Appears to be using an older version of GIT: 2.10.1, instead of 2.17.1
OSX 10.11.6, SourceTree Version 2.7.6 (177)
Like 15 people like this
Paulo Oliveira
October 12, 2018
Worked wonderfully! Thank you.
Clint Anderson
October 24, 2018
After months of just putting up with this issue, and hours spent trying to get it working again to no avail, @nebrekab's suggestion solved my problem.
Jan Vrabel
November 8, 2018
Use system GIT also solved this problem for me. Even when system git was in use -> switched to embedded and back to system, same version, same git, but it works now
Like 4 people like this
Chao Feng
January 19, 2019
Google and tried for several hours, USE SYSTEM GIT is the only way works for me.
rafael perez melendez
March 19, 2019
@nebrekab
has the only working solution so far... it shouldn't be a comment
21 votes
Ana Retamal
April 5, 2019
Hi everyone, this is Ana from the Community Support team!
We’re seeing several recent responses saying that the solutions provided here do not work. This post originated in 2012, so whatever was valid at that time doesn’t necessarily need to be valid now. There could also be different reasons why Sourcetree is asking you for credentials, so there isn’t really a unique answer.
To make sure we’re helping everyone, I’ll be closing this thread now. If you encounter this issue now and the solution provided here doesn’t help you, please submit a new question and make sure to add the following:
  1. If you’re using Sourcetree for Windows or Mac
  2. Which operation where you performing when you were prompted for your credentials
  3. Provide a screenshot
Thanks and see you around :)
Ana
123 votes
scars
November 30, 2017
1. go to terminal in your project folder
2.
git config credential.helper store
3.
git pull
 4. input your username and password
curtisr_jigawatt
December 20, 2017
This is the only thing that worked for me. Thanks Albert.
A E
December 25, 2017
+1 THANKS!!
Like 2 people like this
cperez1989
January 12, 2018
This works for  me. Sourcetree 2.7
ttn January 30, 2018
This works for  me. Thanks!!!
siyabongantombela
July 22, 2018
This is the only solution that worked for me. Using sourceTree 2.7 for Mac. Thanks!
Kankuro
July 31, 2018
Everything else above failed to work, this worked perfectly though, thanks!
Kenneth Requina
August 7, 2018
This worked for me
Peter Willand
August 8, 2018
The only one solution, that worked for me.
SourceTree ver.: 2.6.10.0
System Git ver.: 2.18.0 + git-lfs v2.4.2
Win 10 Pro 64bit
Thanks!!!
Nicolas Milcoff
September 13, 2018
This worked for me (macOS). Thanks!
huizhang
October 10, 2018
This works for  me. +1 THANKS !!!
Umang Savaliya October 29, 2018
Worked for me.
Dhruv Aggarwal
November 4, 2018
Thanks ,
Worked for me as well
Charne Fourie
November 7, 2018
This was the only solution that worked for me. Thanks so much!
Fabrizio Masini November 9, 2018
this is the real good solution.
Especially because, in case you don't have https support in your server, you cannot just switch to it...
Thank you very much!
Deleted user November 11, 2018
Simple, correct answer. Thank you!!
keen_foong
November 12, 2018
This one has been plaguing me for months. Thank you!
Anish Kumar
December 10, 2018
This worked for me. SourceTree 3.0.1 on macOS
Tarashor
December 10, 2018
Bourados
January 2, 2019
Well done, That is perfect.
Is that a bug ?
Michael Dmitriev
January 7, 2019
thank you!!!!!
Wing
January 8, 2019
This worked!!
powellian
January 30, 2019
Nice one! Worked simply/easily for me and - based on the upvotes and other people it worked for - this should be the accepted answer.
hong nhan nguyen
February 24, 2019
This worked for me, Thank you!
March 19, 2019
This also works!, looks like the only one that doesn't work is the accepted one :p
syedfaizanahmed
March 19, 2019
This really worked for me after so much wasting effort on other solutions. Thank you so much Albert!
Source Tree: 3.1.1
Xcode: 10.0
29 votes
Owen Peng
February 23, 2015
I have same problem and troubled me for a long time, now I found a solution.
1. go to terminal in your project folder.
2. run #git pull
3. input your username and password
4. go back to sourceTree and run Fetch or Pull, it does not ask your password again.
bgerth
July 9, 2015
This worked for me too
Björn Broer
August 26, 2015
Amazing! Thanks for this, it works like a charm. After doing the Git pull command in Terminal, the next time you fetch, pull or push, it asks to allow Keychain to be accessed by Sourcetree, and when clicking on "Always allow" you don't have to enter your password anymore!
kmerhi
October 5, 2015
Thanks for the tip - this solved my issue as well!
Jason Harlow
February 23, 2016
Thanks for pointing this out - totally worked.
aryoxp
May 16, 2016
This solution is only working on Terminal. @Steve Streeting solution is working for me, SourceTree 2.2.4, Mac OSX 10.11.3 El Capitan
Deleted user October 18, 2016
arcrus
October 25, 2016
Thank you!
TrungVuANT
November 8, 2017
I tried but no success, but then I figure out:
- SourceTree use Embedded Git service
- Terminal use System Git, which I install via XCode
So, I just need to update SourceTree config via "Preferences -> Git tab -> Git Version" by select "Use System Git", then everything works well
Don't forget run steps as @Owen Peng suggest above. good luck
Like Tom Nguyen likes this
Minh Huynh
November 26, 2017
Thanks @TrungVuANT
It's totally working with your solution.
"I just need to update SourceTree config via "Preferences -> Git tab -> Git Version" by select "Use System Git", then everything works well"
Ajit
January 25, 2018
Thank you so much @Trung Vu !!
Updating  SourceTree config via "Preferences -> Git tab -> Git Version" by select "Use System Git" works for me.
Brian Sexton
July 10, 2018
@TrungVuANT's solution worked for me.
Vinh Tran
August 8, 2018
thanks @Trung Vu it's worked for me.
20sk
August 21, 2018
Helped in my case. Thx!
Fawad Tiemoerie
December 1, 2018
Helped me. Thank you!
Hrtz
December 1, 2018
This works!
Thank you... I almost went crazy!
13 votes
CobaltGray
August 4, 2017
This has been bugging me for ages. I have an answer that now works for me on SourceTree V2.6 (123).
First go to keychain and remove any bitbucket entries (you may not have to do this but it helped me to work out that sourcetree had actually entered something)
Under sourcetree->preferences go to Accounts
Click edit
Change Auth type to "OAuth" from Basic
Click on "connect account"
login to the bitbucket page from the pop-up window
Make sure protocol is 'HTTPS'
Hit 'Save'
Bring up one of your git repos and pull it from bitbucket.
The first time it will ask if it can access keychain. Hit 'Always Allow'
You should then have pulled the repo.
Check in Keychain access to see if there is a new entry called 'Bitbucket Credentials'
If you have this then sourcetree should not ask you for your bitbucket password in future.
Time will tell if this keeps working. Good luck.
Brian Farrell
August 26, 2017 edited
OH SWEET JESUS!  After searching about this problem for over an hour and trying several different fixes, this is the one that FINALLY WORKED for me.
I had previously set-up two-factor authentication for Bitbucket and tried using an 'App Password', but that was not good enough. I couldn't make the repeated auth requests stop until I switched from 'Basic' authentication to 'OAuth', as Darren suggested.
I am running SourceTree 2.6.2 on Mac OS Sierra 10.12.6
Sanity Restored.
Thanks, Darren!
Like CobaltGray likes this
ethanbeyer
After a previous reply that said I had fixed this with System Git, I was still prompted over and over for BB creds.
Darren's solution seems to be working though!!
furey
September 22, 2017 edited
Woo-hoo!
Thank you, thank you, thank you.
Cheers, @CobaltGray!
Note: I had to make sure the protocol was set to 'HTTPS' before logging in from the pop-up window.
Adam_Mendoza October 18, 2017
  🔥 yup, that solved this issue for me.
ethanbeyer
I keep getting emails about how other people solved this, and smh, @CobaltGray still has the only answer that worked for me. I'd upvote it more if I could.
7 votes
Paw Baltzersen
January 5, 2017
Crazy that this is still an issue after so many years, but I ran into this today. The fix was to install git on the computer and use that instead of the embedded version. After a git pull and entering the credentials there I can now work in SourceTree without it asking for password all the time.
Deleted user March 1, 2017
This worked for me, too. Thanks!
bastula
July 17, 2017
Tried so many other solutions, but this is the only one that worked for me.
Ján Marcin
October 16, 2017
Thank You! All I had to do was switch from Embedded to System Git.
4 votes
Tom Brückner
This is driving me MAD. Every once in a while, typically after some obscure update, SourceTree on MacOS starts to require my password on any push or pull action. Sometimes it works for months, then suddenly, I have to type in my password again. This is so strange. What is causing this, and why can't they fix this once and for all?! I am really considering to switch to GitKraken now.
ethanbeyer
+1
3 votes
Thomas Scheelhardt June 27, 2017
We are seeing this eaxct problem for two accounts on our Team and it seems Atlassian have no clue what is going on, since they choose not to offer an answer to this crippling bug.
We have tried all the suggested 'fixes' but none have worked.
A source control system that you cannot access is not only completely worthless it is also endangering projects.
Atlassian how about you actually address this matter, since by your own account you are now comitted to provide support via the community.
Tom Brückner
For me, setting the Git client to "System Git" has solved the problem for now. But I have no clue why this has to be done once in a while. And until then, I already have forgotten that this setting is available. It's a shame that remembering the password does not just work out-of-the-box. This is such an essential feature, especially if you're using long, cryptical passwords, as I do. Always having to open your password manager is pretty annoying.
Yeah if it was only an inconvenience it wouldn't be quite as bad, however we have users that are denied access to their account after a while of having the 'Ask for password every time' issue.
So basically the problem escalates from an annoyance to a complete blocker.
sscarduzio
July 30, 2017
Thanks @Tom Brückner setting "System Git" solved my issue for now.
ethanbeyer
Setting Sourcetree to use System Git worked for me as well.
If I HAD to guess, I would imagine this error is permissions-based. If the copy of Sourcetree tries to read the keychain value for bitbucket, and can't, then it needs to continually ask.
When changing to System Git, since it's apart of the user's path, I think it actually triggers the system to display the dialog box asking for permission.
Again, at any rate, using System Git and running `git pull` worked for me.
Like cellepo likes this
Antão Almada
November 2, 2018
I don't understand why there is a seemingly great accounts feature but still get keychain pop-ups...
Darren Dickerson
April 20, 2017
This is still happening.  Strangley it seems that if there are many differences SourceTree flakes out and tries to authenticate.  You should be able to duplicate this by say coping a version of a project that has CR/LF windows style line endings but the repository has Linux style line endings.  Removing the windows style line endings stopped SourceTree from trying to authenticate.
Pavan Kalyan Tolety April 19, 2017 edited
Remove all other authentications section in sourcetree other than git hub.
Then click Add or either go to Hosted repositories(to quickly check if it was successful) and click on edit accounts.
In credentials select OAuth and select refresh token. You will be redirected to bitbucket website and click on Grant access.
Now goto your fresh account in sourcetree and select Set as Default.
Done. Now you should see all your repositories in hosted repositories. It shows login error if it is not successful
Mike Lebon
February 26, 2017
I was running into the same issue and then realized that my SSH agent did not have my SSH keys loaded.  So make sure that you have your SSH key loaded if that's how you are talking to your git repo server.
See here for more details of how to check you agent and see which keys are loaded:  https://confluence.atlassian.com/bitbucket/set-up-ssh-for-git-728138079.html
Also see this if you discover that your keys are not loaded at startup/login on macOS Sierra:
https://blog.elao.com/en/tech/ssh-agent-does-not-automatically-load-passphrases-on-the-osx-sierra-keychain/
Hope that helps
Jagadeesh
December 10, 2018
I too faced the same issue and got resolved.
Please follow below steps to resolve.
Source Tree -> Tools  -> Options -> Updates -> Click on 3.0.12.2543 for update
Source Tree -> Tools  -> Options -> Git -> GitVersion -> Click on Embedded and Update Embedded buttons.
Restart source tree and it works fine.
Amen Asli
March 5, 2019
same worked for me
RajanandP October 18, 2018
Came across this same issue and multiple posts too. So consolidated my research and fix at one place https://stackoverflow.com/a/52884626/5107365. Summary is, problem solved when I used the same password for Atlassian's account address(which is the Gmail ID I used to OAuth to my bitbucket user), as that of my Gmail ID.
Chandru
June 29, 2018
Christopher Morris
April 12, 2018
I just changed my password is it is no longer asking me for my password every few minutes.
eacikoglu
March 13, 2018
Use stable version 2.6.3 to get rid of this problem.
link :https://www.sourcetreeapp.com/download-archives
Dale Swift
March 1, 2018
Using ssh connection but always prompted for a password. If I enter the password several times push does work but the password is never saved.
For me the solution was a bit more obscure.
By default ssh will always check for ~/.ssh/id_rsa and attempt to use that for any connection. In my case that id is not relevant for git, but is used for ssh to a different server.
The solution is to add a an entry in ~/.ssh/config which tells ssh to only use password.
Add the following lines:
Host myhostname
PreferredAuthentications keyboard-interactive,password
nuthinking
March 31, 2016
Check in your settings in the Bitbucket account. On mine it was using https, I put ssh and all fine now.
Dmitry Maslov
May 11, 2014
I had the similar problem. Every fetch/pull/push action requires password from my github account. I found the answer for this problem here
https://answers.atlassian.com/questions/219115/changing-password-in-source-tree-1-6-1-mac-13<br< a="">>
It helped :)
Mikkel Riise Lund November 23, 2013
I have the same problem as Anton Trapp. Has a solution been found?
Anton Trapp July 10, 2013
Same thing here. Every day when I start Sourcetree and try to access a remote location (username IS included) sourcetree deletes the keychain entry and after that it tries to access the entry (which was deleted some milliseconds before). Keychain for bitbucket than contains the new entry (bitbucket.org). If I quit Sourcetree and start it again (the same day) it is working with the keychain entry. One day later, same problem.
wborczykincuvo
April 15, 2012
Sourcetree keeps asking me for login and password when pulling from external git or mercurial repository. I've tried different things:
- removing keychain entry: no result
- reinstalling sourcetree: helps, but the bug re-introduces itself soon and then until next reinstall it is still there.
During single pull it asks for password always two times. Adding user name to connection stirng helps in the form, that it remembers user name but still asks for password.
Post a new question
Upcoming Sourcetree Events
