Sourcetree not responding when opening specific repositories
artbrander July 3, 2019 edited
Sourcetree randomly stops responding when I try to open specific repositories. I've tried uninstalling and re-installing, and cloning the repository from Bitbucket, but it still does not work.
Is there some kind of cache or something that I can clear? I'm at my wit's end.
I'm on Windows 10 running the latest version.
Mike Corsaro
July 8, 2019
Hello! Is there anything special about these repositories? Are they on a network drive, or really big? Also, are they repos that I can download and see on my machine?
It might help to try and disable libgit under Options > Git as some repos do not play nicely with it.
artbrander July 8, 2019
Thanks! I checked the box labeled "Disable Libgit2 Integration" and it seems to be working now!
