The colors for changes (red for deletions, green for additions) became a dark gray for both
F_A_R September 28, 2018
So far, the colors for changes have been the expected red for deletions and green for additions.
Upgrading to 3.0 (199) changed both colors to the same dark gray. This happens for both themes (light and dark). Please see the right side of this screen capture:
Any hints?
Thanks.
F_A_R September 30, 2018
Solved:
First, I quit Sourcetree.
Then, I did a deep dive into this file and invested some quality time searching for possible clues:
~/Library/Preferences/com.torusknot.SourceTreeNotMAS.plist
After being satisfied with my observations, I obliterated the XML contents related to all occurrences of this regex:
Colour.*300
I restarted, to settle the system cache dust.
Big sigh of relief.
BTW: This annoying behavior happened under both macOS High Sierra and macOS Mojave.
