Hello every1.
I have encountered an issue with my SourceTree Application.
There is a total white page in the commit section except for branches and tag labels, and latest branch (remotes and local) versions.
Here is a screenshot:
I have removed sensitive information from the stamp, but you should still be able to understand the problem
I'm using GitLab CE as code history manager.
Could you help?
Added;
I've found a workaround by switching the light theme to dark theme.
Thanks.
Today, installing the update 3.4.23 this bug does not appear
I've open a ticket https://jira.atlassian.com/browse/SRCTREEWIN-14484
Same issue here, ever since updating from Windows versions 3.4.16 to 3.4.18 last week. Neither reverting back to an earlier version nor deleting user preference files has worked. As also reported by OP, dark theme works fine.
Hi
I'm glad to hear that i'm not alone :)
By the way it's kinda frustrating beacuse dark theme doesn't work very well :/
