Unable to connect to remote BitBucket on local device using SourceTree
Hazel
February 9, 2022
I'm unable to perform push, push, fetch or any action that requires connection to remote BitBucket, from local device. I can push and pull from another device using the same account with no problem, so I'm convinced there might be some configurations issue/error in my local device, but unable to identify the problem. I've tried most of the solutions here, even uninstall, removed leftover atlassian folder and reinstall, but it doesnt work.remote unauthorized, authentication failed.png
Alex Koxaras -Relational-
Hi @Hazel
You managed to setup sourcetree from other devices the same way, but on that specific computer is causes you problem?
