What are the required ports for Sourcetree
Emanuel Y January 28, 2019 edited
I'm currently doing a POC to show the value of using sourcetree. However, I seem to be blocked on port 443 when I perform a clone to my local. I looked at the community notes and Stack flow and I received two conflicting reports. One says ST uses standard ports 80/443 for http/https and 22 for SSH...  the other says Atlassian stopped using 443.
Your assistance would be truly helpful.
Manny
minnsey
February 4, 2019
Hi
The standard ports should be fine. Where did you see that 443 is no longer in use?
