I had to change my jira password and now source tree does not work
Hi @fXc6_pPq_ ,
Can you please check the below settings in your PC.
Control Panel\User Accounts\Credential Manager
find the source tree credentials and update the password here with new. can you try this, it may helps you.
Thank you very much this did it for me.
But I did change 3 local passwords:
git:https://bitbucket........services
git:https://USERNAME@bitbucket........services
sourcetree-rest:https://USERNAME@bitbucket......services
Changes the "sourcetree..."-pwd was not sufficient I think.
However, this is solved.
Thank you
This solution doesn't solve the problem at me. in control panel / user accounts / credential manager - I have no stored credentials at all.
