I installed SourceTree 1.6.25 on my work computer this morning (fresh install). Upon trying to "clone new" Bitbucket repository, i received the following error:
git-remote-https.exe - entry point not found
The procedure entry point SSL_CTX_set_alpn_protos could not be located in the dynamic link library
C:\Users\myuser\AppData\Local\Atlassian\SourceTree\git_local\mingw32\bin\libcurl-4.dll
I've searched my machine for older copies of libcurl-4.dll and no copires are found. I checked the system path for anything suspicious. I've done extensive google searching and I haven't found any answers to this issue.
This error is preventing me from cloning any repository. How do I fix this?
I've been struggling with similar issue where a fresh install of SourceTree on a different PC failed to clone with an error saying it couldn't find a DLL (specifaclly LIBEAY32.dll). It is all installed and working correctly on another PC. Eventually I found that 37 DLL's are in: C:\Users\myName\AppData\Local\Atlassian\SourceTree\git_local\mingw32\bin
But they should also be found at:
C:\Users\myName\AppData\Local\Atlassian\SourceTree\git_local\mingw32\libexec\git-core
After a Copy 'n' paste of all 37 DLL's into the git-core folder and it is now working. Hope this helps someone.
Thank you Todd Dowty! This worked for me! Is this an installation bug? Should this be elevated to the SourceTree developers somehow? I'm not sure how these issues get fixed permanently.
Beautiful. Had this issue and no help anywhere. I can't imagine how you came up with this solution and just amazing that this can happen with a fresh installation. Thank you thank you thank you.
Thank you so much!
Thank you so much!
Had this problem after an upgrade. Your solution worked for me. Thank you.
Thank you!!! fixed my of "
Thank you very much Todd Dowty! You solved my problem!
[Note: in my case, the missing DLL's were 38]
If this is an ongoing issue for so many, why doesn't Atlassian release a fix for this?
LOVE YOU! Thanks a lot!
Thank you so much!
It works for me! thanks man!
You'd think an answer with so many upvotes would get the attention of Atlassian and actually a fix for this in future builds. I hope they are reading and making changes!
I have tried all the suggestions out there and failed. This worked. Thank youuuuuuuuuuuuu
Thank you.
I have to say it is beyond ridiculous that it's been over a year and an issue like this still hasn't been addressed.
Thank you.
Iam use Windows 10 64...
I ended up dumping SourceTree and gong with GitHub's Windows client. Atlassian should stick to web apps or get a competent Windows team to make SourceTree software. It is quite embarassing they can't get their act together for this software.
Thank you very much.
I've had problem with different dll and the copy 'n paste solve my problem.
My problem was: The procedure entry point EVP_aes_128_ctr could not be located in the dynamic link library, in the library libssh2-1.dll.
I'm just putting here the message and dll to facilitate others who has the same problem.
Again. Thank you.
Thanks! That worked for me. Too bad they don't have this bug fixed in over a year.
Awesome quick fix, to the point and accurate. :-) Thank you!
I created an account just to commented here and say thank you so much!
I ran into the same problem this morning. I fixed it temporarily by installing the CLI Git client from https://git-scm.com/downloads and changing the Git setting in SourceTree to use the system Git client.
Not really an answer, but if your under a deadline.
I had CLI Git client already installed and switching to the "System Git" instead of Embedded Git work for me as well. Was struggling with a lot of the "entry point" errors. Thanks for the suggestion.
I temporarily resolved this issue the same way as Dwayne by not using the built in Git client. I also do not have libcurl.dll in the windows folders above. Some posts I read on other sites said Office 365 (which I have installed) may be causing a conflict. I just installed the latest the SourceTree update and this did not solve the problem. I have not received any information on a fix. This problem is currently unresolved for me. The embedded Git client still will not work.
Hi David,
Yes it did resolve for me. Please make sure you enter the correct http path from git when inputting to source tree.
I'm having the same issue, and I don't see libcurl.dll in either of those folders. Was this ever resolved?
Try removing libcurl.dll from C:\Windows\sysWOW64 and
C:\Windows\System32. Looks like it has libcurl conflict.
Dolot
Yes, this finally did help for the LIBEAY32.dll located in C:\Windows\sysWOW64. Thanks to all!
