Osx v. Sierra
Source Tree Version 2.4 (89)
Before I used PC/Win7 with repos in a linux with smb share witout encoding problems.
Now using the same linux repo opened mounted with sshfs into the macbook
Now when making changes into files (php, utf-8) the comment window shows the ä and ö charachters wrong
//liian pitki√§ taulunimi√§, katkaise
If i change the file to iso-encoding, still shows them wrong with other invalid charachter. In windows was no problem.
Can I make commit without messing everythin up ?
Can I fix this with some setting ?
You should check the git diff like thinsoldier suggested. If the problem is just with the SourceTree preview, it will definitely be safe to commit - SourceTree doesn't use it's own code to modify your repository, it just calls git commands.
If the characters are messed up in the git diff, the this isn't a SourceTree question, it's a git question. Someone here might still be able to answer, but you'll find a broader audience of experts by posting the question on a stack exchange site or in a git irc.
If you do git diff from terminal, are the characters still messed up?
It's possible the source tree's preview is just buggy but the actual data that git itself is working with will be fine.
Also the preview window is blinking 5-12 times when changing into source tree window.
