Sign up Log in
sourcetree push git-LFS fails with missing refs but CLI succeeds
Garry Haywood
We have a problem when pushing a git-lfs enabled repo (master and branches all have the same problem)
When we push via source tree (2.4.8.0) Git (system 2.16.1 64bit) and Git-LFS (3.2.4 and bitbucket adapter 1.0.6) fails with a fatal error
Git LFS: (3 of 4 files) 1.53 GB / 1.89 GB
EOF
error: failed to push some refs to 'git@bitbucket.org:kinicho_dev/qqta.git'
Yet if we push with CLI (mintty 2.8.3 x_64-pc-msys) it succeeds.
Two things to note:
  1. The only difference we can see is is authentication - sourcetree is authenticated with 1023 key generated by putty while CLI is with a 4096 key generated by OpenSSH from the command line. Could this be the culrpit?
  2. A GIT_TRACE when pushing with CLI shows a skipping files message, is SourceTree not handling these and causing the error?
Any thoughts gratefully received.
Mike Corsaro
February 27, 2018
Hello!
Could you try enabling "Enable verbose console output" under Options > Git, and also enable "Always display full console output" under Options > General? After doing that, could you try pushing again and then provide the output?
