sslv3 alert handshake failure
kiddoware
December 1, 2018
I suddenly started getting error when doing a pull from remote repo: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Everything was working well till last night and nothing has been changed.
Source Tree version: 2.4.80 running on windows 10
kiddoware
December 3, 2018
I got it resolve, by uninstalling sourcetree and git also and doing a fresh install of sourcetree with integrated GIT. Please give it a try.
Dave Rushton
just tried it and am still getting the same error. Thanks for putting up your solution though!
rasxod
это не вариант у меня 200 репозиториев
Like Senthilkumar S likes this
21 votes
rasxod
есть решение
надо обновить встроенный GIT
rgyalrongskad December 3, 2018
Спасибо большое, все решилось!
Dave Rushton
Update Embedded Git worked for me. I didn't understand any of the text but I DID understand the image. Thanks!
Like 5 people like this
Dineshikalakmalidisanayaka Dissanayake
December 3, 2018
Thanks ! It Worked
Sergey Gussak
December 4, 2018 edited
That worked, thanks! I used system Git, which was v 1.x, and switching to Embedded Git, which is 2.x, and updating it helped. It looks like Atlassian changed something in Bit Bucket over the weekend, and it rendered it incompatible with the old Git versions. Probably, upgrading system Git would help too.
Like Pradeep Paneru likes this
wtarte
January 10, 2019
Worked here too.  Thanks a ton
gold0206
January 28, 2019
Awesome. That worked.
eldersilva
March 10, 2019
Thanks for the solution, solved my problem.
uoc1691
April 8, 2019
This worked. Thanks!
djwendel April 30, 2019
Same here - thank you!
Tigran Minasyan
June 4, 2019
Thanks! This worked.
Anuj Mishra
August 5, 2021
Perfect Answer, works like a charm, I additionally also updated the mercurial version as well now all authentication is working.
Pradeep Paneru
December 13, 2018
My similar issue was resolved by re-installing GIT. Due to the system limitation, I had to install GIT version 2.10.0.
KarthikVeera
I managed to fix my issue by
A. Go to "Tools > Options > Git" and selecting "Use System Git" instead of "Use Embedded Git".
Mohammad Nur Uddin
May 6, 2019
how can i go to "Tools" ?
Like Akhil Aggarwal likes this
rasxod
win 7
I have the same error
fatal: unable to access 'https://***@bitbucket.org/***/***.git/': error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Dave Rushton
I also have the same error. VERY FRUSTRATING
Dave Rushton
I have used SourceTree for the past 3 - 4 years and had no issues until now. I uninstalled and reinstalled both Git and SourceTree and I still get the same error
Like FinixChang likes this
studiospec
June 13, 2019
Appreciated!
