I have an open calendar (towards my organization) with the scheduled maintenance added as events. This is manual work at the moment, both registering the event in Statuspage, and then add the same information again for the same time slot in Google Calendar.
Is there a way to automate this process, and have the calendar event created automatically based on the information entered (date, time start, time end, and heading as a minimum) in Statuspage? I have not found anything in the manual, and so far nothing via integration platforms like Slack or Zapier.
Br, Rune
Great question. Unfortunately, this isn't a feature that we currently have and there aren't any workarounds that I know of other than manually adding the maintenance schedule.
I am not certain this feature will be implemented in the future, but we will most definitely send out email announcements for any feature updates that we do have.
Thanks @Mark Campbell-Vincent for clarifying. Although not the answer I was hoping for, it is still of value to know.
How can we contact product management to get this on the roadmap?
Yes, put me on the list for that feature too :)
Manual import "works" but changes in rotation and overrides aren't publish so it's not bulletproof.
+1 for gCal integration!
+100 We need that as well!!
+1
