×I want my banner to be the entirety of the screen and make it a link that redirects to my webpage. It would also be neat to remove the small gray banner with the name on it
my page is https://siriusbot.statuspage.io
but id like to have it more like this https://status.discord.com/
Hi Naexy,
Welcome to the Atlassian Community! I'm Nick from the Broadcom team, long-term Statuspage customer.
You will need to use Customization for this and use CSS to modify the div that controls the banner. Customization is on higher plans and requires custom domains.
If you're going to upgrade + add custom domain, you'll want to either make the width to 100%/100vw on masthead-container or cover-image-container, not sure which one but playing around with the CSS will work.
Hope this helps!
Nick Coates
Product Owner - Service Status, Broadcom Inc.
