Is it possible to create lineage between two components?
Mariann Francillon February 25, 2022
I would like to create a component that represents the Tableau Dashboard A. A shows data from a query from a dataset B.
I would also like to create a component for B because some teams use B directly.
Is it possible to link those two components so every time I report an incident in B, A is also part of that incident and sends communications to its subscribers?
John M
February 28, 2022
Hi Matthew,
While there is no feature that makes one component 'dependent' on another component, you can add multiple components to a group, and then when creating an incident, you would select the group, rather than the component.
First, add a group to the component:
Then, select the group when creating an incident and all of it's child components will automatically be selected:
Mariann Francillon March 1, 2022
Hi John, thank you for your reply.
Unfortunately, the components are already added to my team's group. Is there a way in which I can have more than one level of groups? E.g. creating a subgroup inside of a group.
Thank you!
John M
March 1, 2022
Hi Mathew,
Currently there is no option for parent-child group relationships, however I did find a feature request already in our system for adding component groups as subgroups.
Like Mariann Francillon likes this
