×Hello,
I am trying to update the status of a component using python and i am not able to get it to work. I am getting the following error
Helper python code
import requests
import json
class StatusPageHelper:
def __init__(self, url):
self.url = url
self.url_prefix = "https://" + url + "/v1/pages/"
self.session = requests.Session()
def updateStatusDashboard(self, token, page_id, component_id, status):
self.token = token
self.component_id = str(component_id)
self.page_id = str(page_id)
self.status = str(status)
print(self.url_prefix + page_id + "/components/" + self.component_id)
headers = {'Content-type': 'application/json', 'Authorization': 'OAuth ' + self.token}
self.data = json.dumps({"component[status]": "partial_outage"})
print(self.data)
self.session.headers.update(headers)
response = self.session.put(self.url_prefix + page_id + "/components/" + self.component_id, data=self.data, verify=False, timeout=30)
if response.status_code == 200:
print("{0}: Update success".format(self.url))
else:
print("{0}: Update failed: {1}".format(self.url, response.text))
Error:
api.statuspage.io: Update failed: {"error":"component is missing"}
Can someone help me to get the code to work or point me to the right direction as this is not helping. I printed the full url and it seems to be correct
I figured out my mistake and got it to work.
so how did you get it to work?
Also when i tried the same with Curl the command worked. So its kind of surprising that Python is not working
