help me recreate customers from deleted statuspage
Ricco Trudslev
September 30, 2025
Hi Support team
I've cancelled my subscription as we're currently having 2 statuspage subscriptions. the old one is cancelled recently, but i would really like to get a csv of the customers opted in to the status messages. can you please help.
Dan Breyen
Hi @Ricco Trudslev welcome to the community.  I'm assuming you are using the cloud. Not being an expert on the Atlassian API calls, you could try these wo calls that might help you out.
You may need to reactivate your subscription to get the API to work.
I think you could use the "Get Organizations" to get all of the organizations setup and then "Get users in organization" to pull the users for each Organization.
Here's a list of the JSM Cloud API Calls that you could use for reference.
Hope that helps.
