×Hi All,
I have installed PlaySQL spreadsheets plugin in Confluence.
Suddely a question arised to me about the scenario when multiple users are working with same spreadsheet and perhaps they end up with editing the same cell.
When this happens latest changes are considered by the plugin without any notification to the users. Because when the second user changes and tries to save the data, it was already changed by someone else, so the new user should atleast get a warning or operation should fail asking user to reload the data before saving changes.
Currently does the add-on (PlaySQL Spreadsheets/PlaySQL Forms) support any configuration to prevent this somehow?
Thanks in advance.
Parimal
Solved! Go to Solution.
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
