×The How to Run Effective Meetings course links to the What three things would you recommend to your co-worker to help run better meetings? article written by @Andrew DeBell Unfortunately, comments are now closed on that article. This is me posting the comment I had drafted in reply to the prompt in the course:
"What three things would recommend to your co-worker to help run better meetings?"
1. Lean into the "invitation" part of a calendar event and make attendance optional
2. Build-in time to either refresh or engage with the meeting pre-work during the meeting
3. Begin with the end in mind: what are you trying to achieve with this meeting? Could you achieve that outcome without calling a meeting? Use that instead and prioritize everyone's calendar.
Number 1 is my weakest! This is a great list and one I will keep front of mind. Thank you @Tyler Sellhorn !
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
