I am unable to download the sample slide template for the Learning Circle - is there a way I can be sent a copy of this?
Hello @Kristy Borgonah
I just received an answer from the team that was handling your request and they mentioned that some adjustments were done and now the file can be downloaded.
Can you please check if you can download the sample slide template for the Learning Circle now?
@Petter Gonçalves The link is not working for me. I get a "Something went wrong." page when I click on: https://www.atlassian.com/dam/jcr:bdbc9c86-7593-4b44-b943-a40324782d5e/Learning%20Circle%20Deck%20Template_Final.key
I was able to download the file using archive.org, but the .key file doesn't open in Keynote (on mac and icloud).
@Kristy Borgonah thanks for pointing out this bug! I'm working on locating the slide deck and will get back to you.
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
