Hey there! Just discovered the project poster and I think its awesome. Especially the problem space is definetely the thing we were missing a little bit whie we dove too fast into the solution space :)
But we have (yet) a small product and I wondered if you guys would create a project poster for each new feature? Then it would be more a feature poster. Does that make sense? :)
Also, du you then create a product requirements page (solution space) as a child page within the project poster?
Cheers, Lars
Solved! Go to Solution.
@Dominic Price how does such a Feature Kick Off looks like in Confluence? The product requirements blueprint isn't really helpful when you are not desiging a feature from scratch or desigining multiple user stories at once. How das a single Confluence page dedicated to only one or two user stories looks like?
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
