How to start using Atlassian Cloud for FREE! | 6 steps to get Confluence Cloud FREE | Add Jira
2 comments
Robert Hean
Hey @Tim Braxton - lots of great info in there, and appreciate you sharing what you've created!
Some thoughts:
  1. You may want to look at breaking up the Confluence doc a bit. As it's currently setup its a very long text doc, which quickly causes me to lose focus. You could split it up into smaller docs to help folks use it more easily.
    1. How to get a free instance
    2. Concepts (what's a space, what's a label, etc)
    3. How to integrate Jira
    4. etc
  2. Your Confluence doc seems to mirror the youtube video - you could insert chapter links in the Confluence doc to give folks easy access to visuals.
    1. Adding images in the confluence doc could also help
  3. You may want to look into formatting options on the Confluence page (e.g. the /layout macro) to help break up the text
Like Tim Braxton likes this
Tim Braxton
September 20, 2025
Thanks so much for your suggestions, @Robert Hean. You helped me to get creative with the documentation. I used the same public link for the starting page and kept a copy of the original so others can see what it initially looked like. I'll probably go back through and add some more screen captures. Any other thoughts?
The updated documentation is at the same Confluence public link as before.
How to start using Atlassian Cloud for FREE! | 6 steps to get Confluence Cloud FREE | Add and integrate Jira
The Original (new public link)
(Original) How to start using Atlassian Cloud for FREE! | 6 steps to get Confluence Cloud FREE | Add and integrate Jira
Thanks again!
