×Hi folks
My two favorite project management tools are Trello in collaboration with Todoist.
I order to automate my tasks I've been searching for an IFTTT applet to get assigned checklists from a Trello card into my Todoist inbox.
Have any of you found that service? Or can you Trello developers create that applet?
I'm sure many others will get benefit of this kind of flow automation.
All the best,
Simon
Hi Simon,
Sounds like a great idea! We're not directly familiar with a way to do that, but I would suggest taking a look at Zapier, which is similar to IFTTT, but tends to have many more connection abilities, and you can probably set this up to send data from cards you're assigned to over to Todoist: https://zapier.com/zapbook/trello/todoist/
This isn't something that we're able to build for you, unfortunately, but let us know if you have any questions. Zapier's support team is also a great resource for setting up Zaps.
