The Original Card Counter for Trello extension for Google Chrome was working fine two days ago and now it's like it's not there at all: no number of cards anywhere. Is anyone else having this problem?
I'm the author of Original Card Counter for Trello, i don't use Trello and didn't get feedback the extension was not working.
I'll provide an update to make sure it works again 🙂
Same problem. I can't find any counter that works
https://community.atlassian.com/t5/Trello-questions/trello-extension-not-working-problem-with-input-element/qaq-p/2518722
best answer
https://community.atlassian.com/t5/Trello-questions/Extensions-not-working/qaq-p/2501939
I've published version 2.0.0 of the extension it should work again now 🙂
Thanks a lot Tim, good job!
Your new version is working.
@Karl Macnaughton I think Trello has stopped supporting various Chrome Extensions. I use the Card Limit Power-Up and Dashcards Power-Up for counting cards!
I added this powerups but its still not showing Card Counter
If you're using Card Limit, You'll need to click the three dots at the top of a list and set a limit for the list (it doesn't matter the number) and then it will show you a count at the top.
If you're using Daschards, you'll need to go into the Power-Up (click the button at the top toolbar) and then make a filter to say where you want to count cards.
Today I've published version 2.0.0, can you try again please?
None of my chrome extensions currently work. Board filters aren't working correctly either. It's a pain in the ass.
@Josh Moffatt if you're having issues with board filters, you can reach out to https://trello.com/contact and they should be able to help if there's some sort of bug!
