Sign up Log in
Automation variable for card email
Jesper Ellegård October 4, 2023
Hi, I wish to use the {} variable for the card email ("Email for this card") in a rule.
I can't see it on https://support.atlassian.com/trello/docs/butler-variables/
Can anybody help me?
Thanks in advance
Jesper
milynnus
October 4, 2023
@Jesper Ellegård
There is no specific email variable but you can use text custom field for it and use {{%Email}} - custom field name assumed to be “Email”.
Thanks for the reply, but its not a custom thing: on any card under Share there is a specific non-custom email-field, generated by the system.
It's the internal variable for this I need
Best regards
milynnus
October 4, 2023
@Jesper Ellegård
If you are referring the email associated with each card, then there is no variable for it.
Ok - thanks a lot :-)
