Automation variables for dates
Julian Stang May 7, 2023
I want to send a custom E-Mail notification when a certain checklist item is completed. Within the E-Mail, I want to mention the date two weeks from the date the checklist item is marked as complete.
Is there a way to access the date like {date} and add two weeks to the current date?
Thank you very much in advance!
Best
Alex Koxaras -Relational-
Hi @Julian Stang and welcome to the community,
Outside of the box, trello offers these automation variables https://support.atlassian.com/trello/docs/butler-variables/ in which there isn't any direct reference to the date of the checklist. So I would assume that out of the box you can't do that. In jira there is the lookup component to look for issues (card) under certain criteria. I would try to find a powerup to do this kind of automation.
Thank you for the fast answer!
I just want to use the {date} variable but add 14 days to it within an E-Mail, is that possible?
Best
@Julian Stang try to write {date+14d} or {date+2w} and let me know if that did the trick.
Or if you want working days then {date+14wd}
Read more here https://support.atlassian.com/trello/docs/arithmetic-and-formatting-in-date-variables/
Thank you very much, that worked!
