Best time tracking and invoicing solution for Trello
Erica Wheeler
April 29, 2018
I would like to track time on lists in Trello and then be able to invoice based on that time. Anyone using integrations that are awesome? I'd be very thankful for some direction on getting the right combination. On a budget so pricing is very important. Free or inexpensive is a must for me at this stage. Thanks!
Jodi LeBlanc
April 30, 2018
Hi @Erica Wheeler - Harvest helps your team track time and then turn that data into insightful reports that shine a light on your projects. You can track time right from your Trello cards using the Harvest Power-Up.
Here are the details:
https://blog.trello.com/trello-harvest-integration
There is a 30 day free trial so you can check it out before committing.
Hope this helps,
Jodi
Genti Tola February 19, 2024
Card Time In List by GTOLA provides all of the following at a fraction(at least 3 times cheaper) of what competition is charging:
- duration
 visual insights through the card badges
automatic time-tracking
- reports, exports and much more!
George April 15, 2021
We created a time tracker for this exact problem, it's called Rotor, version 2 is in beta right now check it out here: https://rotor.to
Marta Kostova
April 16, 2021
It looks similar to what we've developed to fix the exact same problem as @Erica Wheeler It is called Assista and can be found in Trello's Power-Ups listing.
Assista can export all the data in .xls so additional transformations are very easy.
We use it in Camplight to invoice our clients as we work on an hours basis.
Cheers! :)
Monika June 27, 2019 edited
Hi, we are working with zistemo which is incredibly simple but powerful.
I assume we tried them all but we always missed easy to manage timesheets without switching between Apps. Zistemo has a easy to understand visual feedback and you are able to manage and edit your timesheets inside Trello.
Monika
Erica Wheeler
June 27, 2019
Thanks so much! This might be exactly what I was looking for!
