I'm trying to create a button to create another unique card in a list.
How can i tell to butler to check that this card is not altready present in all the boards?
I can only make it check the same list where butler is trying to create the new card
Hi there,
Right now, you aren't able to check across the entire board before creating the card, the condition will consider just the list you're creating the card.
