Can i filter on more than 20 boards?
Judith Kruidhof
October 23, 2023
You can set a filter to search by different boards. now I have 25 boards to filter from.
unfortunately, trello indicates that the maximum board search is at 20.
can this be changed to 25 or 30 boards?
Brittany Joiner
@Judith Kruidhof you might need to use a Power-Up to do this. I don't think Blue Cat Reports has a limits of the number of boards you can use to create what they call "lists" (basically table view with more advanced filters).
