I have problems adding the "Connect and Sync Boards with Unito" power-up to a board.
As far I understand I should see it next to "... Show Menu" in the top right corner after it has been enabled. That is however not the case.
If I click on the menu in the right hand side, it is listed under Power-Ups, and if I click it, I can choose between "View Power-Up" and Disable.
Any idea what I do wrong?
Hi Bjørn,
Sorry to hear about this!
You should see a button titled "Board Sync" in your board.
If you're not seeing this please reach out directly to Unito Support at https://unito.io/contact/
-Leslie
