Card Colors Change When Past Due?
troy.sivak August 16, 2019
I use the calendar feature regularly.  I want the cards to change color when 1) nearing the due date, 2) past due, and 3) completed.  How can I do this?
Ollie Guan
Hello @troy.sivak ,
If the task is overdue, the card's due date will be displayed in red. Once the task is completed, the card's due date will be displayed in green. Is this the result you expect?
troy.sivak August 19, 2019
@Ollie Guan That is kind of what we are looking for.  We use one board solely for a calendar.  I want a bright display of 1) near the due date, 2) past due, and 3) completed.
Brittany Wispell
Hi @troy.sivak
I have not seen any power ups that might be able to do this.
I did find a power up that shows the ticket aging please see images below. Screen Shot 2019-08-16 at 9.31.22 AM.png Screen Shot 2019-08-16 at 9.32.34 AM.png
Brittany Wispell
You could also use Butler to add a specific colored label for tickets that are about to be due.
Like • troy.sivak likes this
Thanks @Brittany Wispell .  We're going to try the Butler option.  It looks like it is what we need.
Brittany Wispell
Good luck! The labels might be worth utilizing if you don't already use them for something. It might be a good suggestion to the butler team.
