×I am trying trello and in order to effectively complete tasks i need to categorize my cards by projects. Right now it is a mix of different tasks on different work projects and also mix of some non-projects tasks. Right now it is a bummer. Is there an effective way to categorize them?
There is a Power-Up now that allows for parent-child relationships in Trello now called Hello Epics.
https://blog.trello.com/trello-card-dependencies-hello-epics-power-up
Does this solve your problem?
Thanks for the feedback
Not really, no
It does create connections between different cards and it does them "parent-child"-ly, but it doesnt' really create a connection i was going for. For example strong connection would actually bind cards to category. If category is moved to another list - then all cards within it would do so. If category is deleted - so is the childs of it.
The worst is though that i can't really see any visual changes in lists. They are not really connected. If childs would have a padding from left and category would not have one - that would make a difference.
I hope i made my case - though i am not really sure.
You could accomplish this with something like ButlerBot by making your own automation rules, but I don't know of a solution or Power-Up out of the box that will do this.
If you want to check out ButlerBot, here's a link: https://butlerfortrello.com/butlerbot.html
Mind you, it might get a little complicated with the intricate rules it looks like you want.
