Because I have not found another method, I commonly use Trello checklists as collapsable ordered lists. In order to collapse a checklist, all items must be checked as completed, which changes all item text to strikethrough formatting. This is all wonderful for checklists, but makes ordered lists harder to read, meaning every item in the checklist is typically deselected for viewing and then reselected afterward.
Is it possible to add a checklist function to the checklist icon which would select or deselect all items in the checklist (depending on the selection state)? This would be immensely useful.
If this is not possible, would it be possible to create a secondary option to allow users to collapse entire checklists regardless of completion status?
Please add this basic checklist feature : check all / uncheck all
Yes Trello Pleaseeee! This would make my day to day so much easier!
I found this thread looking for the same answer.
I have created an automation -> button that unchecks all items in my checklist. This can be set to uncheck all checklists in a card or just a specified checklist. This works for me.
Thanks heaps Paul. This works really well and is simple to do:)
What one cannot do is use regex for checklists with names having varying parts. For example
regex:/^List name.*/
won't work for a list named "List name 23". I'm not sure why that is or why partial matches isn't just built in.
Our team has also been looking for the same thing. Each morning we have a checklist to compelte, but it is a pain to uncheck everything every day only to check it all again.
One suggestion till this basic feature comes:
Create a template card with your checklist.
Every morning create a card from it and you can check each item and archieve once done. Repeat everyday. :)
Right now, that it is not possible to collapse single checklists within a card. But I'll make sure to share the suggestion with our team for consideration.
Same Here. Chech/uncheck all feature would be great! Thank you
Please provide a check/uncheck option for confluence task lists
Me too. We need Checklists at Confluence which uncheck itself after reloading. So every user can check repeating processes, supported by a checklist.
After six years, yes, please create checklist check/uncheck all button. Especially annoying for mobile users which cannot use browser extensions and scripting.
I was having the same problem. This Chrome extension solved my problem https://chrome.google.com/webstore/detail/confluence-cloud-uncheck/mndfdglbjiklkaadbpbndpegplbacohb/related
It's not the best solution, but...
Is the chrome extension still available ? I am unable to find it.
It's been a while since I stop using that extension; no problem, I just stopped using it. I found "box unchecker" in the chrome extension store but I have not used it.
Our staff has been looking for a way to utilize the checklists for more routine tasks. Every Monday-Friday there's a certain list that has to be accomplished for each day and with interuptions and calls, it can be hard to refocus every 10 minutes to where you left off. Each day has it's set list. Each week our staff has to uncheck each item on a daily card "start over". We tried the repeater power up and while it does create a new card that has items unchecked, it doesn't delete the old cards. So the clean up time by deleting old cards takes just as much time. I think a select all toggle to select the check list items would save a bit more time. We are new to trello but love it so far. I even use it at home for taking care of an elderly parent to track medical care. If there is an easier way to help with weekly tasks, we'd love to hear about it. Thank you!
This doesn't work for me because we have a living list, things are added to it frequently. This would mean adding it to the current list AND the template list, which no one is going to actually do. It's really NOT that hard to add a check/uncheck all button - Like. Every. Other. Checklist. Software. Has. It's been YEARS and they still haven't managed this...
You can also have a card reset all checklists when moved into a particular column. So I have cards sent back to the to do column every day at midnight and automatically resets the checklists.
My solution to this problem is 2 steps: (1) set all checkboxes in the task list to "checked", (2) remove all the checkboxes marked "checked". Please see https://www.screencast.com/t/7MTxrrRuuV7
As you can see from the screenshot, I have added an html macro to my page, and inside the macro is the code, which I will share below so you don't have to type:
<a id="addAllcbx" href="#">Add checkboxes</a> <script type="text/javascript"> AJS.toInit(function () { AJS.$('#addAllcbx').click(function() { $( "ul.inline-task-list" ).find( "li" ).addClass("checked"); }); }); </script>
Hi Khuong Vu,
I've used your macro but the issue with that is if I refresh the page, the boxes will still be checked.
Within the .click() function you should not use the .addClass() method, but instead .click() on the correct "checkbox" element.
When you .click() it, it will complete the necessary server requests to actually check them off without just making them look checked off.
Hello @Ryder Wishart were you able to use this macro?
I changed this to use it with the click() like you said:
<a id="addAllcbx" href="#">Reset checkboxes</a>
$( "ul.inline-task-list" ).find( "li.checked" ).click();
</script>
But nothing happens on the page. And the developer tools are not helpful, no error message is shown.
You can create a custom button for checking all and/or unchecking all. Go to Automations>Custom Buttons>Card Buttons
Click Create Button: choose your icon, name your button, and click enabled by default if you want it to show up on all your cards
Click Add Action
Select Checklists
Scroll down to the option 3rd from the bottom (at the time of this post) which says:
Check all the items in checklist checklist name on card
You can choose check or uncheck, you can select a specific checklist or you can apply the action to all the checklists on the card.
Thanks a million Erica, I tried here and worked perfectly!
