Set of processes as advised to achieve the above is convoluted. Need to have a cleaner way to indicates dependencies between checklist items (whether within the same card or in a different card). Is this feature on the roadmap?
Maria from Planyway will be along shortly....😂
Until then...I will explain that Trello is inherently a flat system but you can very effectively create hierarchy with it.
Please check out this article, it may help:
Another amazing tip is to use this linking to be able move dates of linked items, giving you that dependency management within Trello.
Check out our good friend @Brittany Joiner video here:
https://youtu.be/P3ksEfktjz4?feature=shared
