Custom Fields Powerup
katie chase
Is there a power-up similar to Custom Fields that allows you to have a larger text area where you would like in a card? The current custom text field is pretty useless if you're trying to see all the text similar to the 'description' box.
Iain Dooley
@katie chase there are a few ways you could achieve something like this, for example the NoteJoy power up would allow you to edit some text within Trello's desktop or web app interfaces, you could link to a Google Doc, probably other things.
Can you describe your use case in a bit more detail? What information are you storing there and how do you need to use it?
katie chase
I like the description box the cards have and want to add another box just like it. But that doesn't seem to be an option.
Like • 2 people like this
atlassian, opsgenie migration, jira service management, incident response, on‑call management, alerting tools, migration guide, devops operations, service reliability, atlassian learning, migration best practices, opsgenie support, IT operations
Join the Opsgenie Migration group 🚚
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
