Custom color cover
Jim Brown December 11, 2023
I would like to create a solid color cover with a company logo in the corner. When I create a cover as a jpg, it is shaded black or white from the bottom up, losing have the cover and logo. Is there a way to display a full color custom cover?
Daydreamer Mike
Hi @Jim Brown
Welcome to the community, please try setting your card cover size to 768x160...
See below
Jim Brown December 12, 2023
Thank you for your suggestion. The size works perfect. But I am still getting the shading that is covering half the card. Im trying to make the top card look like the bottom card and still have the emblem.
Like Alexandre Lindolfo likes this
Daydreamer Mike
Hi @Jim Brown
The card back and card front have different ratios.
The card back is 5:1 ratio, so 768x154 works perfectly when you open a Trello card:
However, it shows like your example and the one below when viewing the card front (from the Trello board)
To get the best aspect ratio for the card front (what you see from the board, I suggest 2:1 ratio, which looks like the second card above ☝️
However, that doesn't show full width on the card back, when you open the card.
I guess it is up to you to decide which one is most important to you, view from the board or view when you open the card...
By the way, if you want slightly taller cards, 4:3 ratio works too for the card front
Alexandre Lindolfo
September 16, 2024
The same is happening to me
I wish the colour was like when the settings is opened (top image)
Then the blue colour gets differente and the shading appears (bottom image)
Is there a way to fix that?
