×I am trying to get multiple dates entered on one card to show up in my calendar.
I have enabled the Custom Fields powerup and I have added a date custom field to my cards but any date entered here does not show up on my calendar. It is still only showing the Due Date on the calendar.
I have tried enabling and using Planyway powerup calendar but still no luck.
Is it possible to have Custom Field dates show up in the calendar?
Hi Phillip, no, custom fields calendar dates do not show up on the calendar, only the due date of the card.
@Katrin Anger Is there a way to put in functionality requests with the Trello team? This functionality to be able to see custom field dates in a calendar view is a critical missing piece for us.
It's the same for us, a critical missing piece. So is it possible with functionality requests? @Katrin Anger
My team would also like to request this missing functionality. @Katrin Anger
Same issue please add this functionality
What's the point of custom date fields if they won't show on a calendar?
Really. Just think about it.
It is mind boggling how no one in atlassian team has thought of this when implementing the customs field feature
Don't you guys use Trello for brainstorming and concept validation? :)
We also need this functionality quite urgently. Trello team, can you please help with this?
My team is also in need of this feature. We're looking into alternatives to Trello because of this
Pretty pretty pretty please???
Hi, I've just posted a question and wonder if anyone here has found the solution as similar problem. We want to be able to see start date to end date on the calendar (not just when tasks are due). Basically to see works in progress and identify pinch-points/availability in workload.
I thought of Custom Field but looks like this doesn't sync to the calendar.
What about Harvester?
Has anyone had any other break-throughs?
Katie
Oh i also need this feature so badly!!!! Or at least know how i could do this differently. I have 3-4 custom fields i need to display in calendar.
Another user needing this functionality. I know how easy it would be to code this.
My team and I also need this feature badly!
A badly needed function.
Oh we need this urgently! Please!
This is a crucial requirement for us as well. Now each card may have due dates for individuals and an overall due date. Not being able to use this limits our use of Trello. We have to use another board just for this which is too redundant and unproductive. Please look into this. We would pay a premium for simply using this. But without that, the premium plan is pretty much useless to us.
@Nathan Smith Seems like we're not the only company to need the functionality to add multiple dates and times that sync as a single event with Google calendar. This omission basically makes Trello worthless to managing our workflow and, considering the functionality exists elsewhere within Trello, it seems bizarre not to have this already enabled.
Same
It's 2024 and I'm here looking for the same thing. Like other have said , what is the point of have custom field dates if they dont show in calender or timeline??? Come on Trello!
Start and Due dates are useless for us. Each job (card) needs to be able to have many dates showing on the calendar. Add this functionality please.
This is indeed super annoying. In the interim, a janky workaround is to add a checklist item and assign that a due date. That shows up on the calendar view.
It would also be helpful if all due dates would sync with your Outlook calendar as well, including checklist items (which is not currently the case).
To automate the "janky workaround", I have created a rule for each custom field (e.g. "X") as follows:
When custom field "X" is set to a date, add item "X" to checklist "Checklist", and set the item due on the date in the custom field "X"
This skips the manual step of creating a checklist, adding the item and date, but just copies in whatever is set for the custom field.
Indeed, besides just being displayed on the front of the card, these automation hacks seem to be the only thing custom date fields are actually useful for.
Another team needing multiple dates to show up and to be able to customize better the reminders... like Google calendar, weeks, months prior to the deadline. Reminders with notes/titles would be amazing.
I found a way to add multiple due dates to your calendar!! Add a checklist with the list of due dates, then assign a due date to the task. It shows up on the calendar view of the board (top left, click "Board" dropdown, select calendar) then you can sync the Trello calendar to your personal calendar.
Hope this helps!
Seems like this is unchanged from months ago, but adding my support to this request. Seems like a pretty big omission.
Everyone in this thread please vote for and watch this issue in Trello's actual issue/feature request tracker: https://jira.atlassian.com/projects/TRELLO/issues/TRELLO-138
@Megan Kelly @Jennie_Malmberg @Katie Buckwalter @Amanda V. @David Klein @Russell Semenov @Alyssa Boente @Wout Funnekotter @Glenn Mc @Kelly Herbert @Josephine L @Marius Antares @Kamilla Kristensen @Eignamiðlun ehf @Stephan Goldmann @Daniel Mee @Nithin Mukundan @John Pujol @Agent Services @Ron
I need two dates and to differentiate between them in calendar view, Customer picks up and Pick up from customer. There is no difference between Start date and Due date in calendar view so it is useless to me. Strange obsticle.
Trello just did an update with a calendar view of your boards (there’s also a map view, and timeline). When I add a checklist to my card and assign due dates to checklist items, they show up on the calendar view. I haven’t tried to sync this with my email calendar yet, but I keep trello open throughout the day and can see upcoming due dates for my to-do items in the calendar view. Hope this helps!
