Custom fields
Alexandra Heyraud May 10, 2022
I would like to know if it is possible to insert custom fields on a Trello card without these fields being automatically positioned in all the cards of the board?
I could see that the question was asked several times on the Atlassian support in 2021, have there been any changes made since then?
If not, where can I make a request to Trello?
Thank you for your answer.
Alexandra Heyraud
Aiyoku
Unfortunately, no. Custom fields still show on all the cards inside a board, but you can leave them empty if you don't want to see them on the front side of a card. If you want more control over custom fields, there is a similar Power-Up called Amazing Fields that allows you to filter out certain fields from showing on cards, but the fields themselves don't show up on mobile.
