Data Loss (Do I need to worry or does Trello have it under control)
hearsay
April 8, 2018
I love Trello. I just started using it for work and school. My one and only concern is data loss. With previous apps I could ease this anxiety by simply backing up my data. I have never had to rely on any of those backups but if I needed it I could simply import and all would be back to normal. With Trello I have found this is not possible. Yes, I can download a JSON file of my data, but this certainly isn't the same. In the end, I would need to reenter all of the data manually anyway, so that feature seems pointless. Probably useful for coders and developers.
Anyway, is data loss something I should even concern myself with? Maybe not. Perhaps I should just relax and rest assured that my data is being professionally managed by the folks at Trello?
Sloan
April 9, 2018
Hi @hearsay
If you want to export all your data you can. As normal user only JSON files.
As business class user it is possible to download all your boards into CSV-Files.
Here are some resources that may help you:
To calm your concerns, Trello has a whole page dedicated to explain their data safety. Trello does backups and tries to hold up a 100% availability. :)
More here: https://trello.com/trust
Cheers
Niklas
