For some reason, all my lists on my Trello Board have been collapsed so I can't see my cards - this is a really daft question but how can I expand them? Double clicking doesn't seem to work???? I must be missing the obvious!!!
Hi @ayoung !
You probably applied a filter of some kind. Do you have a green box up towards the top right of your board that looks like this?
If so, just hit that X and your cards should come back :)
Most likely you hit Q, which is the keyboard shortcut to only show cards you're assigned. My experience has been that this is the easiest to accidentally hit. You can type Q again to get rid of it, or just click the X there in the green box.
Hope this helps!
I am new here. All of my lists suddenly are collasped. I cannnot open them using your suggestion and wonder if there is another way. Very confused. Fran
In same boat
thanks man; you've saved my day!!!
This helped me!!!! Thank you!!
