HOW TO CHANGE CARD BACKGROUND COLOR?
Fabio Trastamara
How do I change the color of card background?
11 votes
Mike
May 8, 2017
Hi Fabio,
Right now, you can only change the background for the entire board, and you can't set background colors for individual cards.
However, there's a Chrome extension that you might want to look into, that does allow for that: https://chrome.google.com/webstore/detail/card-colors-for-trello/nodlpencjjlohojddhflnahnfpfanbjm?hl=en
Fabio Trastamara
Michael thank you very much. If I can pick your brain or experience, how can I show the label text on the card and not only the color?
Like • Jim Schwilk likes this
Kaylin Murray June 2, 2017 edited
Hey Fabio,
There doesn't look to be a way to turn on looking at the text of the labels to display, you can turn on color blind mode on your account if you don't want to just use the colors. This article has some helpful tips for how to best use labels.
You can also filter cards if you would like to only see certain cards at a time.
You might want to email feature-ideas@trello.com to ask about possibly turning on the ability in the future to change the color of the card or to display the text of a label!
Hopefully that helps!
Like • hamid sanjari likes this
Sofia Ferreira
August 10, 2019
That would be great if possible
Like • JCShaun likes this
Katrin Anger
August 10, 2019
@Sofia Ferreira @Fabio Trastamara
There is a Chrome extension that lets you change the background color of cards as well as lists: Trello Card Optimizer
Like • 7 people like this
Hubert Kut
@Katrin Anger tried that and works! Thanks for sharing.
Jonathan Smith
September 3, 2019
Is there a feature request for this?
Like • 3 people like this
Stryker Automation
April 15, 2020
Hi the extension https://chrome.google.com/webstore/detail/card-colors-for-trello/nodlpencjjlohojddhflnahnfpfanbjm?hl=en was working fine until last week
would an update to trello have caused this problem?
Colors work for a while but when cards are opened and closed they lose the color
Heidi Reilly
May 1, 2020
Turn on the text for the labels simply by clicking on one of them
Javierabellan
May 5, 2020
The same thing happens to me as to Dennis, it has always worked well but now the colors are being removed, do you know if there is already a solution? Thank you
3 votes
Michael Wolfe
You can add text to your labels by selecting Show Menu > More > Labels > Create a new label.  Now you just need to select the label cover and input some text.  When you add a label to a card the label text can be displayed by clicking on the label when viewing the card on your board.
Deleted user September 28, 2018
To see the label text, just click on 1 of the labels.  There's a toggle that turns them on or off for the entire board when you click on a label color bar.
Mike September 5, 2019
Very helpful! Thank you
Steve Lewis October 19, 2017
Hey Fabio, there is a Chrome extension that allows you to see the label text on a Trello card. its called Trelabels for Trello. I have just started using it but so far its been great.
Steve
Michelle
Awesome thanks for the tip
Daymt
March 17, 2021 edited
How do I get trello to change card colors if I use firefox browser?
Sano
February 6, 2020
How to change card color in the color that i want (not to color based on label color ) ?
