Habit Tracker using up excessive numbers of automations due to daily reshuffling the cards in a list
Rachel Murphy
January 24, 2024
Habit Tracker by Upgrade Your Brain is wasting automations by re-shuffling the cards in my list every day. After moving a card to the Streak Broke or Streak Continued list, it then takes each card in that list and moves it to the top of the list. It uses an automation each time it moves a card to the top of the list. As the number of cards in the list grows throughout the month, this becomes quite a significant number of automations and I just hit my quota limit for the month. I can clear out the cards in the list sooner so there is less shuffling, but is there a way to make the Habit Tracker automation stop wasting automations by needlessly re-ordering the cards?
Alina Kurishko
January 26, 2024
Hi Rachel,
Welcome to the Atlassian Community! 🙂
I might not be the right person to discuss this issue because this Power-Up isn't developed or managed by us here at Atlassian and we don't have any information on the Power-Up or what you'd need to do to change its Automation usage.
I'll leave some room for Community members to share their tips and tricks, but if you don't find a solution, I'd recommend reaching out to the team who developed the Power-up directly, as they should be able to help you with this.
You can contact them by clicking on the Contact Support button on the Power-Up page - https://trello.com/power-ups/5d3f40b4a5f03284e9f3bc24
Hope they can help!
Alina | The Trello Team
Rachel Murphy
January 26, 2024
Thank you! I will reach out to the developer. 😊
Like • Alina Kurishko likes this
Upcoming Trello Events
