there should be a button with a half colored in circle at the top right corner of your screen next to your avatar - click that and select light mode
Klick on your Icon in the top right corner. A menu will appear- Click 'design'. Now choose bright, dark or auto mode.
It's now under "theme". Very hard to find this setting when searching the internet because it was first rolled out as a dark/light circle icon, then switched to "design" and now switched to "theme" (as if dark or light is a theme?)...so the search results are all over the place. UX: 3 versions, each less intuitive than the last? Not good.
It’s true; they should conduct the card sorting exercise once more.
