×Ideally, I'd like to have users, projects, and tasks to be imported into Trello and then have timesheet entries be transferred back to Xero.
Can this be done?
Hi @JME Maxwell ,
Welcome to the community!
Please have a look at this integration tool
https://zapier.com/apps/trello/integrations/xero
Soumyadeep
Hi @JME Maxwell !
I’m pretty sure you could build this workflow with Integromat. There are both Trello and Xero off-the-shelf integrations ready for you to check out. Integromat is a pretty flexible tool so you get to create pretty much any type of connection you need :)
@JME Maxwell the Xero powerup for Trello doesn't do that and as far as I can see there are no timesheet actions in the Zapier for Xero.
If you want this you'd need a custom integration, it's the type of thing I create with BenkoBot:
I've done some pretty sophisticated stuff with QuickBooks Online, Xero has a similar API. If you're interested in getting a quote feel free to reach out.
