{{%Fieldname}}
Hi @Sales Fabrinox 👋
Christl from SendBoard here - makers of the Email for Trello Power-Up.
The syntax you shared looks correct, if you are using Trello's automation email (see Trello's help article here: Use Custom Fields in rules). You will just need to replace it with the actual custom field name - make sure it matches exactly.
From the help article: To reference a Custom Field’s value in an action, use this format: {{%Field Name}}
If you are using a Power-Up like Email for Trello, let me know because the variables differ slightly.
And, if you are having trouble with the variables, please share more details around the exact issue you are having so we can offer advice.
