×I have three boards on trello, the first one is a"To-do list", the second is "Ongoing" and the third one is "Done".
When i create a checklist one the first one it creates a linked card on the second column.
What i want to do is, when i manually change the label color in the first card, all the linked cards on the second column change to same color.
Is there anything i can do?
Hi Luis Miguel Sousa - welcome to the community!
You could create an automation rule when a specific label is added to a card in the 'To-do' list, find all linked cards, and add the same specific label to the card.
For example:
when the green label is added to a card in list 'To Do'
for each card linked in the attachments
add the green label to the card
If you have multiple labels that you would add to the card, then I would suggest creating separate automation rules that mention each label.
I hope that helps!
Thank you, this solved my problem :)
